‎2018-09-2007:44 PM - last edited on ‎2023-05-1903:22 PM by Gordana Radonic
‎2018-09-2007:44 PM
I am trying to override door tags for a portion of a project. I started by creating identical door tags that have different names so that I can create graphic override rules that turn them white on the plan (i.e. not visible when printing). That all worked in model space. However, when I placed that view on a PDF the graphic override does not work?
Check the settings for the view (drawing) that you have placed on your layout.
It may not be set to use the door tag hidden GO.
This is assuming you are publishing your PDF from a layout.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
