Graphic override on column is not working
I am applying graphic override on a elevation Over uncut lines. It's working fine for wall,
slab & beam. But for column it's nit working.
For catagory i choose 'All tyoes' so there should remain be no issue. ARE there any possibility thus override can't work on uncut column line? Or the issue is something else? please let me know ur opinion.
Avi
5 REPLIES 5
It would help us if you share a screenshot of your View GO Rules.
Paul King
I am having a similar problem - though in my case I am trying to override the background fill of only one of the surfaces in my multi segment columns. If a column contains the surface, the entire column appearance is changed, not just the intended surface
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
Graphic overrides will affect the entire element.
They can not override just the sub elements.
It is like with a wall, if you override one surface on the wall, all of the wall surfaces will be overridden with the GO.
Erwin Edel
A way to 'cheat' past this, is to set the other elements surfaces to a solid fill with a white pen in the surface settings. When printing you will not see any difference between this and an empty fill with an empty background. Since you only override the background pen and you are then using a solid white foreground, the end result is the same.
We use this 'cheat' to have vectorial hatch patterns with background pens without using the colours defined by the internal engine.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Paul King
Thanks. Ended up doing something quite similar !
