‎2023-07-27 07:34 AM
I have created a complex section, so can the graphic overlay function fill and cover the complex section one by one?
Solved! Go to Solution.
‎2023-07-27 07:55 AM
I think you mean a 'complex profile' instead of 'complex section' - just a translation mix-up.
Graphic Overrides act on the entire element and unfortunately do not affect individual skins of a composite or complex profile.
So if your GO criteria match any one component in your complex profile/composite, the entire element will be overridden.
‎2023-07-27 08:09 AM
Thank you Barry, I understand your answer. It seems that I have to modify the section manager
‎2023-07-27 08:15 AM
Yes, but it is called 'Profile Manager'.
‎2023-07-27 10:11 AM
Hello Barry: After my experiments, I personally think that it is very necessary to apply the coverage function to every detail of the complex section, which is really necessary.
‎2023-07-27 11:06 PM
I have to say that this is a post with humor....!
