2020-04-2309:05 PM - last edited on 2023-05-1903:21 PM by Gordana Radonic
2020-04-2309:05 PM
I am trying to simplify a few steps to make RCP and other plans easier w/o having to add fills. I currently have overhang/soffit created with a complex profile (beam). I want it to have a simple line fill pattern to define the soffit on the RCP. Is there anyway for it to rotate the pattern depending on the direction of the beam. Is there anyway to set the orientation of the override fill? I attached a picture showing the fills and the outcome I get when overriding the cover fill of the beam.
Unfortunately not. Graphic Overrides will reference Fill overrides to the Project Origin, rather than use the Element's origin. This is a known limitation.
