2020-07-2301:54 PM - last edited on 2023-05-2602:21 AM by Gordana Radonic
2020-07-2301:54 PM
Hello Friends,
I need a solution regarding the grid line.
In the Column Layout, I need to show the entire grid element. (See Fig-1)
In the Wall Layout, I just need to show the segment of the Grid element. (See Fig-2)
I know how to how to show/ hide the entire grid element in the Floor Plan.
To achieve this I needed to draw two sperate sets of Gridline. One for Column layout & other for Wall Layout.
Are there anyway, thus I can achieve both scenarios using a single set of grid lines?
Sadly, I am not aware of any solution.
This should belong to the MVO.
(The workaround is kinda clear at this point: Use an object for it and put this option into the MVO via a mvo object. This fixes at least the problem of needing duplicate lines, which is an error prone thing to do.)
I was gonna suggest that Avi turn off the middle section of the Grid Element line, then draw Line elements (probably on a separate Layer) for the middle sections. Then Avi could save two Views, one with the LInes representing the middle section visible, and one without. The Lines and the Grid Elements could also be grouped.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
