2006-06-07
06:24 PM
- last edited on
2023-05-26
02:35 AM
by
Gordana Radonic
2006-06-08 11:14 PM
2006-06-09 02:10 AM
You can put your grid in certain layer.
You can make visible or unvisible in layout.
Yes. That will do it. I think this is a step in the right direction. Now how do you get it to show at a given scale that matches the drawing you want it to be shown with?This is baffling. I thought by construction grid you meant the grid in View > Grid Options > Grids & Background... if you can put that on a layer, I'd sure like to know how!
As for Drawing in the Master Layout. I was only talking about drawing lines for borders and title blocks. Suppose I want to move it 6" or some specific distance to work better with the drawings in the layout. You can't do that because the Master Layout is 1:1.Equally as baffling. Just drag it over by 6" and it will go 6", relative to the layout. If you're in the layout environment that is and your 'Layout Units' are set correctly in the project preferences.
2006-06-09 03:12 AM
2006-06-09 07:16 AM
Steve wrote:Steve,
What I want to do is have the construction grid in my Drawings show up in the Layout. Can this be done? Yes or No?
If not, then I want to find some other way to show a construction grid...
2014-01-19 10:01 AM
