2006-06-07
06:24 PM
2023-05-26
02:35 AM
Gordana Radonic
2006-06-07 07:26 PM
2006-06-07 07:29 PM
2006-06-07 08:06 PM
Steve wrote:It looks like you can get a grid in the Layout, but not in the drawings themselves.
the construction grid.
View-Grid Options-Grids & Background
It shows up as usual in my drawing but not in the Layout.
I have tried different Master Layout setting too. I can’t seem to make it display.
Perhaps, like Ghost Stories, this is not an option in 10.
2006-06-07 08:51 PM
2006-06-08 12:50 AM
Also, how do you change the scale of grid in a Master Layout?The grid display along with the scale are separate for the layouting environment than the modeling environment.
When I am in a Master Layout I can not change the "Current scale"
2006-06-08 02:47 AM
2006-06-08 03:04 AM
What I want to acheive is "control" of the grids in Layout and/or Master Layouts. Is this possible or not? If you can not dispaly grids in Layout drawings I need to know so I don't wast a lot of time trying to make it work.You can control them insofar as you can set their size, rotation, etc. But it will be the same setting for all layouts and masters, because it's the ame for the entire 'layouting environment'. This grid is different than your 'modeling envirnoment' grid. It's 1:1 - real life measurements
I want to draw some additial things in the Master Layout being used with all of these layouts. This seems like a very basic task. Now go to the Master Plan and try and draw to the same scale. I can't do it. Can you?I wouldn't want to (add anything that was to scale). In fact I would urge anyone not to. The layout book is not the ideal place to do any form of notation apart from title/titleblock information, and maybe the odd amendment note, IMHO.
Or suppose you want to turn on the grid for some reason. This also does not seem like an unusual thing to be able to do. I can not do this either. It will apparently do no good to turn on the grid in the drawing because it will not show up in the Layout. You can turn on a grid in the Master Layout but what scale is it? How do you control it since it does not match the scale of the dialog box for Grids and Background.There isn't. But I suspect that you may be looking for the wrong thing entirely. If you're keen to explain what it is you're trying to achieve and why, then we'd be in a better position to help you achieve it.
There must be setting somewhere that I am not finding.
2006-06-08 07:27 PM
2006-06-08 10:02 PM
