2024-12-07 08:10 AM - last edited a month ago by Laszlo Nagy
Hello!
How can I change the position of the purple node which is connecting the circle of the grid with its line, so that the line is connecting the center of the circle?
2024-12-08 01:28 PM - edited 2024-12-08 01:28 PM
Hi @Zheleva ,
I don't know if I could understand you correctly, but here's a short clip illustrating all operations you can do with the grid marker.
https://youtube.com/shorts/LGYhXiaTqeI?feature=share
2024-12-10 01:38 PM
I want the pink dot of the line, which connects the circle, to be moved, so that the line is forwarding the center of the circle as I showed on the picture.
2024-12-10 02:49 PM - last edited a month ago by Laszlo Nagy
Hi!
Press CTRL+T for the options, go to Floor plan, and set staggering to 0
2024-12-10 04:03 PM
Hi! I want the pink dot to connect the circle on the left side as I have shown it.
2024-12-10 04:16 PM
As far as I know, the default archicad grid marker does not link the stagger to the center of the text circle.
As in, the purple line is not possible, only the red one.
