Grid marker setting
Zheleva
Hello!
How can I change the position of the purple node which is connecting the circle of the grid with its line, so that the line is connecting the center of the circle?
5 REPLIES 5
Hi @Zheleva ,
I don't know if I could understand you correctly, but here's a short clip illustrating all operations you can do with the grid marker.
https://youtube.com/shorts/LGYhXiaTqeI?feature=share
AC 28 INT 5200/WIN 11
I want the pink dot of the line, which connects the circle, to be moved, so that the line is forwarding the center of the circle as I showed on the picture.
CosminF
Hi!
Press CTRL+T for the options, go to Floor plan, and set staggering to 0
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Hi! I want the pink dot to connect the circle on the left side as I have shown it.
As far as I know, the default archicad grid marker does not link the stagger to the center of the text circle.
As in, the purple line is not possible, only the red one.
