HELP! TEXT TROUBLE!
Please explain to this self-taught newbie how is it possible to have text (actual words) in dimension lines instead of the actual dimension numbers?
7 Replies 7
TDabney
Kristen -
It is possible to select the text only in a dimension string - and edit it. You must first place a dimension string, then edit it. The hot spot is around the lower left of the text in the string - I can't remember for sure, but I think if you turn on "text handles" in the display options, the handle might show up and be easier to find. If you select the text and then (keyboard short cut) -> command + T, (mac) - you are able to edit the text.
Hope that was clear enough,
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
kevin b
Tom is right, the display Option for text with handles makes it easier to find the handle which is to the lower left of the text itself. You can also make the changes right in the info box. Once the text is selected, you'll see in the info box the words measured value and under it will be the dimension. Just change the pull down from measured to custom and then type your new text in the box.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
What would be nice is being able to add text (as a suffix or prefix) to a dimension, so that if the dimension itself changed the measured value text would update, but the added text remains. I know in ****CAD you can change the dimension string to "<> blah blah blah" where the <> means "measured value". Is this on a wish list yet?
kevin b
Yes, that would be nice, so you could add stuff like Max., clear etc. to the measured value and not have to redo the manual text every time if the actual length varies. Don't know if its on a wish list or not, yet.
kevin s burns, AIA
massachusetts, usa
Windows 10
You should make a wish out of this.
I would vote ESSENTIAL on it.
kevin b
I guess it is already sort of, see here...
http://archicad-talk.graphisoft.com/viewtopic.php?t=5692
kevin s burns, AIA
massachusetts, usa
Windows 10
That's right, there it is.
