ā2020-07-15
11:03 AM
ā2024-12-30
02:06 PM
Molinda Prey
ā2020-07-17 10:17 AM
Mac_the_arc wrote:
That said I cannot yet get my head around the fact that text within a view will appear on all views, I don't see the sense in that.
ā2020-07-17 01:42 PM
ā2020-07-17 06:30 PM
ā2020-07-20 12:23 PM
Mac_the_arc wrote:Interesting, just had the same thought while reading your lines describing this "customized overrides per layout" approach. The big benefit of applying such settings on a "global" scale is that it's way easier to keep perspective and control - the bigger the project the more important this becomes!
The method you are describing seems overly complicated and would certainly be hugely time consuming, and after the third or fourth iteration of room review would become a commercial disaster for any practice.
ā2020-07-20 05:31 PM
Barry wrote:I found this (among the various that people here have presented) is the best solution for this small issue. To prevent the white surfaces covering things on background, just add a surface override with an invisible material.
Actually you could also set up a Graphic Override to change the element to white.
It won't print but it may still cover what is behind it which isn't a good look.
