cs_ryl
Hide internal walls for concrete slab plan drawing
Hi all,
I'm trying to setup a plan view that shows only the concrete slabs and external walls for now. The way walls have been setup are not through layer so they are all under one wall layer for both external and internal.
I've tried to use Overwrite and turn Position: Internal to be White, but it's still showing up as white colour instead of being invisible.
Is there another way, or different settings that I need to change to make all internal walls invisible?
Cheers!
AC23 AUSTRALIA
MacBook Pro M1 2020 8GB Memory | macOS Monterey 12.3.1
12 Replies 12
No, I have been using Archicad since 1995 and in the last 10+ years I have been studying Revit's capabilities for competitive analysis purposes.
I can recommend that free course Scott suggested, it will provide you with a lot of useful info.
cs_ryl
Thanks @scottjm! I am bookmarking it and will definitely watch it!
AC23 AUSTRALIA
cs_ryl
Aha a real veteran! Thanks for your help @Laszlo Nagy
Guess I will see you all often learning the ins and outs of Archicad!
AC23 AUSTRALIA
