2023-02-11 06:31 PM
Is there a way to hide the tread and riser and set them to finishes only?
I don't want them to show on core only or load bearing elements.
I can't seem to find a way to select, only the entire stair.
Solved! Go to Solution.
2023-02-13 09:01 PM
Check out this post, it includes modified Tread and Riser library parts (Ac25). You can make the same modifications in other versions, it is relatively easy to do:
2023-02-13 09:01 PM
