Hide text Area Fill in some views
Marcus Trimble
Is there a way to hide/turn on and off area fills for certain views?
We have a project with a large number of area fills and it would be good to be able to export a clean plan without the areas.
I know that we could use zone stamps, but I am interested to know if it is possible with fills.
4 REPLIES 4
Gerald Hoffman
AFAIK there is no way to have different view options that would turn fill areas off/on. Perhaps the easiest way would be to just select all the fills and duplicate them. Have one set showing areas and the other not. Put them on different layers and create the 2 views you want with the different layers.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Marcus Trimble
Yep, this is our workaround at the moment.
Thanks,
Johann_P
Just digging up the tread from 2016.
Is there perhaps a better solution for this yet?
Following the described method means I'll have to keep on making duplicate changes to the duplicated fills.
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Use an autotext label in a layer that can be turned off as needed.
The fill layer can remain on and the label layer can be turned off.
