2022-06-28 02:05 AM
Where is the setting that allows the Horizontal Boundary to be adjustable in the Section View?
For some reason they've worked fine until now.
Thanks
Solved! Go to Solution.
2022-07-01 12:36 AM
@James B The icons in the view map match a Section View rather than an Interior Elevation.
2022-07-05 12:05 AM
YES! You did it, thank you very much.
It seems the designer locked this layer to reduce the number of selectable layers.
Thank you very much
