Horizontal lines in section
elk
Beginner
I have suddenly gotten some horizontal lines  in all my sections that I cant get rid off (they seem to be every 100 mm, not sure how they appeared). Does anyone know how to get rid of them?
elk
Beginner
It was a surface setting 😅
4 REPLIES 4
Ricardo Lopez
Hi @elk
Try to switch off the option View> Construction Grid Display
Regards. -
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
It didn`t change anything unfortunately
elk
Beginner
Discovered some vertical lines in another section...
elk
Beginner
Setup info provided by author
