Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
How do I remove these from my elevations
Cant figure out how i did this ! but i want to remove the end points from my drawings ! turn off... I dont know what there called .
Just learning cheers
David Maudlin
tiemi:
Those are probably Hotspots. You can select the Hotspot tool, Select All command (which will select all the Hotspots) than Delete.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Lingwisyer
Guru
Note: Hotspots do not publish.
