2022-06-04
02:24 PM
2023-05-18
05:23 PM
Gordana Radonic
How do I set the 3d front view in the schedule window?
this is elevation view
Solved! Go to Solution.
2022-06-08 04:46 AM
Interesting window.
I have not seen one that is different on the inside and outside.
I was having a look a the schedules and I don't see any way to turn the transparency off - except to use a non-transparent material for the glass.
2022-06-06 11:19 AM
You need to apply a Graphic Override that sets the background pen for cover fills to transparent.
2022-06-06 12:04 PM
I need to remove the transparency.
There is no change. ㅠㅠ
2022-06-07 04:03 AM
All you need is this.
You just need the cover fill active, but I have all 3 fills active.
2022-06-07 11:12 AM
There was a change, but the frame behind it seems to be due to transparency.
front
back
2022-06-07 11:19 AM
Sorry, I thought you were trying to get rid of the colour in the schedule.
What sort of window is that?
I have never seen one that is different on the outside and inside.
2022-06-07 01:20 PM - edited 2022-06-07 01:26 PM
I make window gdl
material Glass - Clear Fast
I am studying Archicad.
It is to try to make the same project as before with autocad.
2022-06-08 04:46 AM
Interesting window.
