How do I set the 3d front view in the schedule window? (transparency off)
LeeJaeYoung
this is elevation view
AC27 on window 11
Interesting window.
I have not seen one that is different on the inside and outside.
I was having a look a the schedules and I don't see any way to turn the transparency off - except to use a non-transparent material for the glass.
7 REPLIES 7
You need to apply a Graphic Override that sets the background pen for cover fills to transparent.
I need to remove the transparency.
There is no change. ㅠㅠ
AC27 on window 11
All you need is this.
You just need the cover fill active, but I have all 3 fills active.
There was a change, but the frame behind it seems to be due to transparency.
front
back
AC27 on window 11
Sorry, I thought you were trying to get rid of the colour in the schedule.
What sort of window is that?
I have never seen one that is different on the outside and inside.
I make window gdl
material Glass - Clear Fast
I am studying Archicad.
It is to try to make the same project as before with autocad.
AC27 on window 11
Interesting window.
