How to add levels on inclined beams
NicolasSolid
Hi all,
I was wondering if someone found a solution on how to create and place Top or Bottom elevations on a inclined beam. In order to add elevations on beams and walls i use labels since the dimension tool cannot work with wall and beams.
My problem now is that we usually use beam tool to model some complex profiled elements like the photo below below but it recognizes only one level and it is not adaptive on where exactly you place it. I hope you understand what my issue is and waiting hopefully for a solution!
0 REPLIES 0
Setup info provided by author
