Archicad design tools: Workflows, element connections, modeling tips
problem: everything is invisible under the baseline |key: column beam cut base level intersection
aryastark
solution: https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=70506&p=315099#p315099
i was a little forgetful (:
• If you still want to use a Slab for this then you will need to place this slab in a dedicated layer with a different intersection number, 0 or 500 and then it will not intersect. -ejrolon
____________________________________________________________________
problem revision (update):
hi,
i found the real problem: that is under the 0 level, columns and beams not showing.
i will watch the video By Hmooslechner until then the problem is unsolved yet.
first version:
valarmorghulis,
i made complex profile.
attached to beam.
used beam magic wand tool to wrap around of basis.
but it didn't work.
when i try to elevate profile to higher than where it should be, it works.
but when i put it to the where should it be in goes almost invisible.
ps->>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
this is basis.
when i change it's reference line to lowest layer & it happens when i try again with beam complex profle.
ps2->>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
ps3->>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
i tried with wall tool by allowing complex profile to use with wall.
but then this dialog box appeared every time.
i tried it with ALL stories. but everytime this dialog box appeared and always complex profile invisible in 3D. (even if continued)
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
4 REPLIES 4
Hmooslechner
Where You can search for Your problems:
It seems to be a problem with the the building-material-domination-number - or with Archicads long existing problem, if You assign walls to the same position line. 2 Walls on the same position make problems. But never heard about problems between slabs and beams.
The try to use a wall: if the slab is down under the current storey, a so small wall is then assigned to the wrong storey and wont be displayd. Trie to make the slab appearing in the storey under as dashed line and then asign the wall-profile down there in the correct hight.
Hmooslechner
Changed the link: https://lbry.tv/@Heimo_Mooslechner:6/Archicad24-tutorial-profilemanager-edges-assigned-to-slabs:5
Hmooslechner
Because this library-link (LBR) is so slow, i switched to Vimeo:
https://vimeo.com/479563572
hope it helps
aryastark
hope it helps
thank you for your effort to solve. also vimeo is 10X better than lbry.tv (lbry is too slow).
but my problem was something else and luckily, found the solution in my old questions archive...
Ver: AC23
Memory: 16384MB RAM
