2006-07-25 12:59 PM - last edited on 2023-05-30 12:24 PM by Rubia Torres
2006-07-26 01:04 AM
2006-07-26 01:21 AM
2006-07-26 10:16 AM
2006-07-27 05:56 AM
We are all hoping that this ends soon and we go back to our normal lives.
2006-07-27 06:15 AM
2006-07-27 06:24 AM
s2art wrote:So you can
ArchiCAD problems seem trivial by comparison...... but with regard to your independant details, can you not "import" them into your project layout using File>External content>Place External drawing in the same manner as in Plotmaker 9? Or am I on the wrong track, as usual?
All the best
2006-07-27 12:40 PM
Chadi wrote:Maybe I'm misunderstanding something, but in the "Open" dialog of AC10 there is a small checkbox "Launch a new instance of Archicad". This way, you can have more than one project open at once. And copy and paste between them.
I have created some independent details in ArhiCAD 10, how do I copy them from one file to another!??
2006-08-24 06:38 PM
Aussie wrote:[If I haven't misunderstood the issue] You can select the browse option on the navigator menu while under layout book view. It will then allow you to drag layouts from other .pln files into your new layout. This is similar to the handy plotmaker 9 feature where you would choose import a layout book and you could then tick off which layouts you wanted.
One of the great missing features of Archicad.
You need to copy and paste or more methodically save as modules, then import into new details.
Same if you need to import any section information added to the Model view.
This needs to be addressed as merging files only gives you the plan information.
2006-08-24 07:26 PM
