How to create Multi Slide doors with 3 sliding door panels?
CL1
How to create slide door with 3 sliding door panels (all sliding)?
Thank you
3 REPLIES 3
CL1
Is there no default library door can do 3 leaves 3 sliding?
Not that I could see in the default library - 3 panels with 2 sliding or 4 panel with 3 sliding.
I could not see anything with all 3 sliding.
But then I do not use the default library, so I am not totally familiar with it.
So you could look for a 3rd party object.
Or create your own from slabs in plan and save as a door object, or use Library Part maker to help you create an object and also co-ordinate the plan and 3D views.
Also try searching in the door settings for "D3 Sliding"
I see there are a few doors in there that say they are 'by-pass' which to me means all sliding.
Some for USA library and the others I assume for INT (others).
I'm having a similar problem finding a slider with more than 3 panels.  The "D1 Sliding Folding Multipanel USA" for instance, does it actually switch to a sliding layout or is the "sliding" in the name just to aggravate us?
using AC26 on a Mac.
Thanks
Designer/ Drafter
ArchiCAD 26 on 27" Mac
