Vasile
Beginner
Exterior sliding doors
Hello, I need some help, please. I want to create a transparent wall with 10 fixed panels and a double sliding exterior door in the middle, but I can't figure out how to set the number of panels from the window options, nor from the sliding door options.
Setup info provided by author
CosminF
Have you tried using curtain wall? It is maybe a simpler way to achieve this.
It will be only one element and you can define the center parts to be sliding doors, facing outwards, with 2 fixed frames each that you need to account for.
This way you have more flexibility with the layout.
Also, when placing markers, you can use the autotext label to assign a label to individual curtain wall panels.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
