How to edit the minimal space settings?
Gisele
How to make the minimal space of a fixture, for example, show with a dashed line and an empty fill?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
poco2013
Mentor
Line type and fill for the minimal space outline is set in the model view options for all objects that use the minimal space feature. AFAIK -- it can not be set individually other than modifying the GDL.
Gerry
1 REPLY 1
poco2013
Mentor
Gerry
