How to make shower screen glass see through in internal elevations?
jay01
Hi there,
Basic question but need help please! We want to do as much drawing in 3D as possible. BUT with shower screens, when we add the glass screen in, we cant see the shower head and mixer behind the glass when we are doing 2D internal elevations. How do you make it so you can see this please?
Its driving us crazy as we just end up using fills instead which creates double ups when we also have sections going through the same room
TIA
Have you tried just turning on transparency in your elevation settings?
You are a lifesaver Barry, thank you!
LamarSampson
I was also having the same issue, thank you.
Setup info provided by author
