‎2016-05-11
10:45 PM
‎2025-02-07
11:47 AM
Aruzhan Ilaikova
‎2016-05-12 11:13 AM
‎2016-05-16 02:53 AM
‎2016-07-12 04:51 AM
‎2016-07-12 05:41 PM
Charlie wrote:My clients always ask about those kind of dimensions too. I get that information into the plan for their review in two ways. (1) I add the dimensions of the bed (for example) to the the GDL script for the object, and (2) I use a second set of smaller, different colored dimensions that will are on a separate layer for easy toggle on and off display.
Sorry to tag on to this thread, but I think it's relevant. I'd like to be able to turn on and off text, like the object title Queen, King, Double Bed. Or the width and depth of an object in plan. Often the client asks "how big is that" or "what size is that".
Would I be better off creating furniture schedules?
‎2016-07-12 05:53 PM
‎2016-07-12 06:49 PM
Charlie wrote:Yes. That's the way I like the objects to work too. And I like those dimensions to be displayed by the object. It is not too difficult to add that script to the objects. I don't have an optimal script for that. Perhaps someone else does and can share it with us. ? I can usually manage a script to get what I need but it is not as efficient as what a GDL Guru would do.
Thanks steve - your image is very similar to what I end up doing. The bed is a good example, but for dressers, showers - essentially any furniture or equipment this would be great. The object dimensions are in the file, but I guess not in the gdl file. I had a macro in 2D CAD that printed the dimensions much like your bed. You had one object, but you could input the object in what ever size you wanted. The text would be associative and update. Kind of similar to ArchiCad zones but in 2d.
