How to remove the underline on elevations ?
I'm looking at the drawing selection settings on layout to remove the underline underneath the elevation name. The only place that I can see if the title line option, which allows you to change colour and line type. I've tried setting the line to white, but it still shows.
I pearsonally don't mind the line, but my tutor will moan at it. They say you should only underline names if their important ]
Thank You
I checked the manual and didn't see a explanation there...
Is this possible at all ?
Thank You
Nice model Nstocks
Ive just tried this and it works
you need to uncheck "uniform symbol pens" option situated just above the preview window in TITLE options in the drawing selection settings, and make sure you have selected a white colour for the line too.
upintheclouds wrote:
Nice model Nstocks
Works just perfectly. Thanks !
