2014-01-20
07:45 PM
- last edited
Friday
Aruzhan Ilaikova
2014-01-23 09:12 PM
2014-01-24 10:55 AM
2015-08-24 07:16 AM
adambeazley wrote:Sadly, seems not to do anything under ArchiCAD 18 - and I cannot even place as a discrete object, even when neofirewall.gsm is included in loaded libraries
I found and answer to my question and just figured I would post it here for anyone else looking for something like this.
I am using a .gsm called NEO Firewall Line, and you can apply it to a selected wall by going to "DESIGN -> DESIGN EXTRAS -->ACCESSORIES --> WALL ACCESSORIES" and selecting the loaded NEO object. Then I would recommend putting it on a separate layer (A-WALL-FIRE) and using an Arhicad firewall line-type. This way you can turn off that layer in any plans which you do not want to see it.
Hope that helps.
2015-08-24 07:41 AM
Paul wrote:Have you downloaded and installed the 'Accessories' add-on?
Sadly, there seems to be no such menu item as "DESIGN -> DESIGN EXTRAS -->ACCESSORIES --> WALL ACCESSORIES" under ArchiCAD 18 -
2015-08-24 08:17 AM
Barry wrote:Thanks Barry - Sorry I edited my post probably as you wrote your reply - but yes, Accessories are installed, and now that menu item is indeed there - but still no luck getting the object to appear. I can select the object as an accessory, and go through a placement process using it - but on completion, nothing appears different on plan - not even a missing library part symbol/spotPaul wrote:Have you downloaded and installed the 'Accessories' add-on?
Download link is in the HELP menu.
2015-08-24 08:28 AM
2015-08-24 08:40 AM
Barry wrote:Good thought - I have previously been playing with reno filters (trying to get them to display fire rated walls differently) but failing to get them to do anything at all - but could be a factor now.
I am guessing it is not layer visibility.
But could it have something to do with the renovation filters.
If you set the reno filters to show all elements does it show then?
2015-08-24 08:49 AM
2015-08-24 09:00 AM
Barry wrote:Just checked, but no - and the object dialog refers to current story of saved view (ground floor)
I see in the original post for this object (http://archicad-talk.graphisoft.com/viewtopic.php?t=13399&postdays=0&postorder=asc&&start=50 ) that it is now storey sensitive.
Could it be on another storey?
