2014-01-03
02:18 PM
- last edited
3 weeks ago
Aruzhan Ilaikova
2014-01-06 10:01 PM
2014-01-07 01:32 AM
khairulfikri wrote:I can reproduce everything you've done. This is a little odd in light of the Help Center information on the hotlinked module functionality of 17:
The problem is that the Master ID doesn't seem to show on the zone stamp. I can see the Master ID added on to the zone ID under Tags & Categories, but the zone stamp only shows the zone ID without the Master ID appended.
Optionally, connect the Zone ID with its Zone Number to display this information in the Zone Stamp.I can't quite sort out how to get that to work as stated. Elsewhere, in the 17 new features guide, it says that the Zone Stamp 2 now does what you're asking for... but I don't see that (quickly) either.
• For example, a Zone with an ID of Bathroom in the source file is placed into the host file as part of a HLM with a Master ID of R213. Its Zone Number will then be R213Bathroom.
2014-01-07 11:22 AM
2014-01-07 12:10 PM
2014-01-08 12:37 AM
Karl wrote:Presumably if you use a zone stamp (eg. Basic Zone Stamp) with the ID enabled within it, then give the placed HLM a Master ID, the zone stamp will show that Master ID combined with it's own ID. I could get the zone ID to show correctly but couldn't get the zone stamp in the placed HLM to reflect all the information.Optionally, connect the Zone ID with its Zone Number to display this information in the Zone Stamp.I can't quite sort out how to get that to work as stated. Elsewhere, in the 17 new features guide, it says that the Zone Stamp 2 now does what you're asking for... but I don't see that (quickly) either.
2014-01-08 10:12 AM
2014-01-08 06:12 PM
2014-01-08 07:50 PM
2014-01-09 12:15 AM
