I need an advice about the best font type to use in documentation
Dears please advise me what is the best font type to use in archicad documentation ?
and what is the best one to use at the same time it will be available inside dwg (cad file)
Regards
Erwin Edel
Don't know if it is the best, but we just stick to default Arial. It means no adjusting font in case you use something you haven't set up in your template with a different font yet.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
I second Arial.
It will be on every machine,
Mac or PC.
If you want something a little more stylish, then you need to make sure every machine that will use your files also has the same font.
And there could be issues between Mac and PC - I recall reading a post just a few weeks ago that seemed to have this problem.
Erwin Edel
There are issues between windows and mac with Arial too, it just has to do with the way each OS scales fonts.
Mostly noticeable in schedules where you have adjusted something to fit to text size.
www.leloup.nl
Windows 10 Pro
