2023-06-12 07:25 AM - edited 2023-06-12 07:27 AM
I want to set the boundary equal.
Above is Text.
Below is the zone label
I want the zone to be like text.
Solved! Go to Solution.
2023-06-12 08:09 AM - edited 2023-06-12 08:10 AM
In the zone label, turn the 'frame' on and also turn on the 'wrap text' option.
Then you can set the frame type and frame width.
2023-06-12 08:51 AM
thank you
I specified the font width for John in the way you said.
Conversely, where is the character width specified?
2023-06-12 09:38 AM
Character width is dependent on the font you use, but you can scale the width and also adjust spacing between characters - this is the same for all texts, be it text, labels, or dimensions.
2023-06-12 10:16 AM
The character width is too wide, so I tried to reduce it, but I couldn't adjust it, so I asked.
2023-06-12 11:54 AM
You said something stupid.
I was confused because I worked on REVIT for a week.
Hey, it works in REVIT too.....
I haven't been able to sleep for days, maybe that's why.
(It's an excuse. ^^)
2023-06-12 01:52 PM
Are you trying to adjust the character width (the word width) or the frame width?
For the frame with normal text, you can just stretch the bounding box hotspots.
With a label you must set the frame width as shown in my first image, or turn the 'wrap text' option off and the box width is automatic (can't be stretched).
