SOLVED!
I want to widen the gap with Story Level.
LeeJaeYoung
I would like to widen the gap between the horizontal line and Story Level like in the AutoCAD image.
AC27 on window 11
17 REPLIES 17
Do I create and use GDL?
I would appreciate it if you could tell me how to use it. ^^
AC27 on window 11
That is up to you.
I have created my own object for floor/ceiling levels, but it is not linked to the actual storey levels.
I just stretch it to the heights I want.
But I am also only doing 1, 2 or 3 storey residential buildings.
Solution
Lingwisyer
Guru
Built-in Storey Marker, line part 2 is the angled bit (1000), which you would probably never use anyway.
Built-in Story Marker cannot be opened.
Excuse me, but can you tell me your exact name? ^^
AC27 on window 11
Solution
File => Libraries & Objects => Open Object by Subtype... => General GDL Object => Ducumentation Element => Drawing Symbol => Marker => Story Marker => Built-in Story Marker
I do not think "Open Object by Subtype" is on the menu be default and would need to be added manually to your workspace. It is the generic storey marker that is included with AC and used when there are no others available. How any of this translates to the Korea menu is a different question...
Thank you I find sotry marker gsm. ^^
Story Marker Object Location - Graphisoft Community
AC27 on window 11
I feel happy with your kind explanation.
thank you so much. ^^
AC27 on window 11
Thank you for answering even the smallest questions. ^^
AC27 on window 11
