I wish there was a way to convert text to either ALL CAPS or to Upper-Lower case and back again
4hotshoes
We run into needing this all of the time. Someone leaves the caps lock on, which is traditional for architectural lettering. But it should also go the other way. Please give us a way to edit text case with multiple options. Otherwise, we have to manually type everything again to comply with company standards. A simple red button could be installed to do this.
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
13 REPLIES 13
Miles,
This is a huge step in the right direction. Thanks!
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
This is awesome to hear! Thanks for the update Miles.
Pedro Melo
I share your interest in enhancing text formatting capabilities within Archicad. To address this, I’ve proposed a wishlist item titled "Text Tool Capitalization Options (All Caps, Small Caps, etc.)", aiming to provide more versatile text formatting directly within the software.
Your support would be valuable:
👉 Text Tool Capitalization Wishlist
DMA_NYC
I run into this all the time. Old School, I prefer text on the drawings to be all caps. (I believe it's more legible on half-size prints.) Besides inadvertently having CAPS OFF. I import text from other sources. If it's more than a few words, I run it thru Adobe InDesign which I also use for standard blocks of text (abbreviations) placing as PDFs.. If that's not in your tool kit, I think Apple Pages, or MS Word can change case.
Still it's probably simple code built into the OS, GraphiSoft could make it easily available. Quite a few low-level conveniences neglected.
Multi-cultural Add-ons? Phew!
AC28 US
