ā2012-02-14
03:52 PM
ā2023-05-26
04:38 PM
Rubia Torres
ā2012-02-14 05:15 PM
ā2012-02-14 06:19 PM
ā2018-05-10 11:28 PM
ā2018-05-12 06:16 PM
ā2018-05-30 04:59 AM
ā2018-05-30 05:50 AM
davidstonearchicad21 wrote:If you use the organiser to drag layouts from one file to another, then the drawings on that layout will still be linked to the views in the original file.
Thanks.
It looks as if the 'Store in' check box is checked by default but that doesn't cut the tie between the projects.
ā2018-05-30 06:48 AM
ā2018-05-30 07:26 AM
davidstonearchicad21 wrote:It is a bit of a tricky one.
I understand that the views on the layouts need to link to their corresponding view of 2D draw space but can Archicad not recreate the views from the information that went across in the copy&paste?
ā2018-05-31 12:44 AM
