‎2021-02-15
12:56 PM
‎2023-05-30
09:53 AM
Rubia Torres
‎2021-02-16 08:54 AM
‎2021-02-17 05:52 PM
‎2023-03-27 11:34 AM
I've got an issue. why the slab is not showing in my section view?
I've attached the image of my drawing
‎2023-03-27 04:43 PM
Is the slab layer turned off or is the slab modelled in the wrong layer and that layer is turned off?
‎2023-03-28 08:25 AM
Thanks for your reply Barry,
I'm not sure, how can I realised that It's modelled in the wrong layer?
‎2023-03-28 08:57 AM
If you can see the slab in plan, select it and see what layer it is in.
Then make sure that layer is turned on in the section view.
Otherwise in the section, turn all layers on.
If you still can't see it, view extents to see if it is possibly far above or far below your main model.
