Interior Elevation - 2D objects vs. 3D objects
rob2218
Please see attached JPG.
basically (for those of you who'd prefer 'reading' than seeing a graphic explanation).
the interior elevations produced from the model aren't up to PAR (don't cut it) when it comes to the linework graphics....so I had to redraw my 3d elevations into 2d...
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
21 REPLIES 21
Eduardo Rolon
It creates an editable "2D sticker" that you can copy/paste as you need, cover up what is behind it and since it is saved as a library part you only have to edit the sticker and it will update all placed instances. In Autocad terms it is a "block". In analog terms it is the equivalent of a "sticky-back" or "stamp pad" if you are familiar with the terms.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
rob2218
wow...now that's a slick function.
Sticker huh...I'll have to try that one perhaps on the interior elevations.
Now do you have to follow the outer contour lines of what you are creating a "sticker" of or can you simply do a 'rectangular marquee' of the "patch" you are trying to mimic?
Interesting...very interesting....
An Archicad "block" huh....i'll have to definately try it sir....thank you.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Eduardo Rolon
AFAIK it is square but it is the same logic as Complex Profiles with the difference that lines are shown
AC29 US/INT -> AC08
another Moderator
rob2218
well....it appears I've busted the "myth" behind the "Patch" function.
Cant' seem to do it in 'interior elevation' view...only seems to be functional in "PLAN view" of the model...bummer.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Eduardo Rolon
Rob, you give up to easily without reading the Manual. You need to define an area using the marquee tool. I tried and it works with Interior Elevations.
AC29 US/INT -> AC08
another Moderator
rob2218
there must be something I'm not installing...not doing properly...it's "greyed" out only when I'm in the interior elevation views....
i>u
Edgewater, FL!
SOFTWARE VERSION:
Eduardo Rolon
DId you draw a marquee around the area?
AC29 US/INT -> AC08
another Moderator
rob2218
sorry...too much coffee this am and deadline looming....
doesn't appear to be working in the plan view either....
is there something...some add-on functionality that needs to be installed?
it's "greyed out" for me in ALL views....what am I missing?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
did not draw "marquee"...sorry will try that.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Eduardo Rolon
DID you USE the MARQUEE TOOL to DEFINE an AREA to be SAVED as a PATCH?
AC29 US/INT -> AC08
another Moderator
