lachiemckern
Interior Elevation ID not changing on plan view & view
Does anyone know why interior elevations are so difficult when it comes to changing ID's and linking to drawings?
I have attached a screenshot of me trying to change the marker "IE01" to "LS01", however it either doesn't allow me to make changes (I've tried this in the project map and view map)- but even when it does 'work' it shows up in the settings preview as "LS01" but doesn't change on the plan when I press OK.
Perhaps I'm missing something but this isn't the first time it's happened with interior elevations and redoing them in this case just isn't viable.
Thanks,
Lachie
Operating system used: Mac Intel-based
Setup info provided by author
3 Replies 3
Guru
Have you tried just having it inherit from the host marker? Since the host marker has changed ID shown on your Project Map.
lachiemckern
Yes I have and it reverts back to the original ID every time
Deviz
I have the exact same problem. Frustrating. But found a solution with the latest hotfix! 🙂
The interior elevation tool however needs to be reviewed. I wonder what is its purpose really, it's more headaches than pros. Doesn't even have the 'fade distant elements' function.
