Interior Elevation & Zone affiliation in migrated 15 project
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-07-18
07:59 PM
2023-05-23
03:12 AM
Gordana Radonic
2011-07-18
07:59 PM
I wanted to post this to see if anybody else has a similar experience when migrating from 14 to 15, whether or not they are using a custom IE marker.
Casey Grimley
AC24
iMac Pro (2017) - macOS 10.14.6- 3.2GHz Intel Xeon W - 32GB RAM - Radeon Pro Vega 56 8GB
AC24
Labels:
- Labels:
Elevations
Interior Elevations
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-07-18 11:11 PM
2011-07-18
11:11 PM
Yeah, I've got that going on too. What is odd is that it is not all the IE's, and not all the views in each IE.
It's not only Zone #, but also <number> and <orientation> auto text doesn't work either, so it may be an autotext issue. I've tried to figure out how and where this linkage is established, but to to avail yet.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-08-09 10:49 PM
2011-08-09
10:49 PM
Yes, this is weird. Thanks for pointing this out Casey. I am glad to know it's probably a bug or something and not user error.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-08-10 06:36 PM
2011-08-10
06:36 PM
Same issues-I started a project in 14, migrated to 15, and none of my auto text for interior elevations 'stick' from session to session.
At first, I associated it from swapping from desktop to laptop, to take teamwork project home to work on...assumed it was this transition which was causing an issue. But now, I can 'fix' the elevation bug, leave teamwork, and when I join teamwork again, on same computer, I have lost that association.
I have gone so far as to make all my bubbles to be 15 library parts; problem does not go away.
-Kathleen
-Kathleen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-01-27 08:33 AM
2012-01-27
08:33 AM
I came across this problem last year in October or so, has anyone found a decent work around or fix to it yet?
I have 450 or so rooms of which I must draw up interior elevations. Manually fixing the zone names will be TEDIOUS, time consuming, NOT BIM and reminds of autocad
it was also reported here:
http://archicad-talk.graphisoft.com/viewtopic.php?printertopic=1&t=37226&postdays=0&postorder=asc&st...
no fix yet? Come on GS!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-01-27 05:09 PM
2012-01-27
05:09 PM
Mark, Seems like the only work around is to use 'Custom' in the marker name and name the marker yourself. Very tedious I know, but it is what it is until Graphisoft fixes the problem.
Casey Grimley
AC24
AC24
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-28 08:03 AM
2012-03-28
08:03 AM
This is a very frustrating "BUG" in ACAD15 concerning Interior Elevation's linked to Zones. Every time I close and re-open a BIM 15 Project all my interior Elevation numbering disappears.
You then have to modify the perimeter of that room Interior Elevation (on each room) or the zone perimeter, to get it back:
Graphisoft has told me that it is project related, so I packaged it and sent it to them... had no response yet! This happens to me when I turn a normal project into a BIM Teamwork project. I will try and save it as a normal project again...sometimes changing one zone and then using the "Update Zone" brings back the names ... Frustrating!!!
