fhedberg
Is there a simple way to do drawing schedule in Plotmaker??
Any response most appreciated
W11 Home | ArchiCAD 27 3001 AUS FULL
7 Replies 7
Scott Bulmer
In PM Navigator, set to Tree by Subset, open/expand subfolders. THEN screen capture the portion of window. Insert that JPG or whatever resulting file into your title sheet. It's not the most highly resolved image, but it does work. Nobody has complained since we have been doing it this way.
Good luck,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Rakela Raul
how do you add down the list your consultants drawings??
do you create pm empty layouts?
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Scott Bulmer
Yes.
Haneef Tayob
I usually create a list in MS Excel, which I then paste in plotmaker.
The link to MS Excel is live, so the drawing is automatically updated if someone (manually) updates the spreadsheet.
The advantage of this is that it's easier to update a drawing list in excel (you don't need someone with cad experience to do it).
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
We do the Same except it is a MS Word Doc and not a spread sheet. It can be argued that one even needs less experience to edit a Word File.
Yet I like the Borders and I can do them much easier in a spreadsheet. We may just switch......
TomWaltz
Our cover sheet is usually an independent detail in the project and we just type it out manually 😞
Tom Waltz
