Is there any reason why the steps of my stair dissapear?
Hi all, I dont know why but the steps of my stairs dissapear on the ground floor story, ive tried to find the solution but cant figure out what is it, u guys have any idea.
Thank u so much
David Maudlin
Forikundo:
When you select the Floor Plan Display > Grid (left panel), what are the settings?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
You have unchecked the "By Model View Options" checkbox so the Floor Plan Representation of the various components of your Stair will have to be defined here in the Stair Settings Dialog.
On the left pane, under Floor Plan Display, activate the Grid page.
Then on the right, at the top of the Grid Components Setting panel you will have a large button using which you can choose which of the various portions of the Grid appear. You can select an option for Relevant Stories, Above Relevant Stories, Below relevant Stories individually.
