Achille wrote:
Since the Revision ID of the Layout is automatically given from the Issue ID, I shouldn't be choosing the "Override Revision Id" option. I'm not overriding anything. I want the Revision ID to match the Issue ID, that I have given. So what's there to override? Apparently for some reason there is a default Revision ID value (01) that doesn't get updated with the Issue ID value.
The Revision ID and the Issue ID are two different things. The Revision ID of a Layout is not automatically given from the Issue ID.
Try this: with a file that has no Issues yet, create a new Issue, set "0" for its ID, and leave the "Override Revision ID of all included Layouts" checkbox unchecked. You will see that the Issue ID will be "0" and the Revision ID of all Layouts will be "01".
By default ArchiCAD includes all Layouts in the first Issue - that is how the program works - since one usually issues a full set a drawings in the Construction Documentation phase, and these will later have revisions as construction progresses and changes arise.
So the Revision ID will be the same as the Issue ID only when you check that "Override Revision ID of all included Layouts" checkbox. Having said that, one can see that Revision IDs are normally the same as Issue IDs, especially if we leave all IDs to default and all Layouts are always included in all Issues. Then one can really get the impression that Revision ID always comes fromthe Issue ID, even when that "Override Revision ID of all included Layouts" checkbox is not checked.
I think this can be confusing because by default both the numbering of Issues and the numbering of Revisions starts at "01" so for the First Issue, if you accept the default settings offered by ArchiCAD, the Issue ID and all Revision IDs will be "01", which can make one think that the Revision ID is coming from the Issue ID. But these are different things.
As there will be many Issues and not all Layouts are included in all Issues, that is when you really start seeing that Revision ID an Issue ID is not the same and that Revision ID is Layout-specific.
In the following image you can see how the Revision IDs of various Layout will become different:
Issue 01: all Layouts were included (I set the Revision ID for all Layouts to "0" manually here)
Issue 02: Only 3 Floor Plan Layouts were included, their Revision IDs became "1".
Issue 03: 2 Floor Plan Layouts and 4 Elevation Layouts were included. As you can see here, the Revision ID of the 2 included Floor Plan Layouts is now "2", while the Revision ID of the Elevation Layouts is only "1" as they were not part of Issue 02. So Revision ID is Layout-specific and is increased only when a Layout containing a Change is included in the given Issue.
Lastly, I also tried that "01" thing you mentioned for newly created Layouts. After closing Issue 03, I created a new Layout and then created Issue 04. When a new Issue is created, all Layouts that were non-existent at the close of the previous Issue will be automatically added to it. So this Layout is added to this Issue, but its ID is "01", and not "0" or "1" so it does not follow the formatting we have with the other Layouts. This might be a bug so I will forward this to Graphisoft. Also, I could not find a place where I could determine the default formatting for Revision IDs. They are always "01". I cannot set it to "001" or "1" or other formatting, or at least I couldn't find the place where I could.
