Guillermo1
Key notes AC29
Hi, is it posible to qantify m2 of walls by their key notes aplicated, or better use ID and properties?
Operating system used: Windows 10
1 Solution
runxel
Since you can in theory put as many keynotes on any element as you want, in every viewpoint, this is not possible right now (afaik), but rather a wish.
That, however, would still be all backwards, because the whole keynote system is not very "BIM"-esque, to employ that overused keyword.
Instead, in a perfect world, we would of course have an automated keynote placing command, that does put keynotes based on the properties which are already inside the model.
So from every perspective, be it the future, or your current concern, IDs and properties are the way to go.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Go to post
2 Replies 2
runxel
Guillermo1
ok, thats why im not using actually the keynote , because are not compatible with scheduling
