fabioferrini
Keynote Tool Limitations in Archicad 28 – Feedback and Questions
Hi everyone,
I’ve been exploring the new Keynote tool in Archicad 28, but I’ve encountered some limitations that I find frustrating. I’m wondering if others have faced similar issues or found workarounds. Here are my main concerns:
  1. Changing an associated keynote
    Once a keynote is assigned to an element, I cannot change it directly via the Keynote palette. The only method I’ve found is to double-click the element and edit the text through the dedicated Keynote menu, which feels unnecessarily cumbersome.
  2. Lack of flexibility with Favorites
    It seems impossible to create a Favorite that only saves formatting settings without also including the specific keynote itself. This might be due to the fact that Keynotes are not part of the parameter transfer options. I find this limits the potential of using Favorites for efficient workflows.
  3. Issues with Excel import/export
    When exporting the keynote list to Excel, modifying it, and re-importing, everything works fine unless I change the name of a keynote already used in the project. In such cases, the labels display missing information. It seems the import/export process is tied to the keynote name rather than its reference number. This makes it impossible to reorder the list during the final editing stages and forces me to keep the original keynote name if it has already been assigned in the project.
Has anyone else encountered these issues? If so, how have you worked around them? Any insights would be greatly appreciated!
Thanks in advance for your help!
Operating system used: Mac Apple Silicon 15 sequoia
4 Replies 4
James B
Thanks for the feedback so far.
In AC28.1 we will add a method to update the keynote label content of an already placed keynote label which should help with your first point.
With favourites, when you use them through the keynote palette it will replace any keynote data and use the one you select in the palette. So you only need the save a few favourites with the formatting you need.  https://help.graphisoft.com/AC/28/INT/index.htm#t=_AC28_Help%2F072_Keynotes%2F072_Keynotes-7.htm&rhs...
For import and export, we kept it simpler to use the key as the references rather than a hidden or technical guid. So it is simpler and clearer on the hotlink side too. A keynote that has changed its key during import, will be considered as a different keynote. https://help.graphisoft.com/AC/28/INT/index.htm#t=_AC28_Help%2F072_Keynotes%2F072_Keynotes-14.htm&rh...
James Badcock
fabioferrini
Thank you for your detailed response and the helpful information!
Regarding the first and last points, I appreciate the clarifications and look forward to the improvements in AC28.1.
As for the Favorites, it would be great to use them solely for formatting without transferring the content of the Key. However, to achieve this, the "Keynote" dialog is missing from the parameter transfer options, which would make this functionality possible.
Thanks again for the support!
James B
From the transfer settings you can exclude the "label text content" to avoid the specific keynote (or property or other text etc).
James Badcock
Brandon-W_DWa
I may have the same issue as @fabioferrini's original #2 concern:
Our firm standards dictate that we have two format types for keynotes:
  1. "Key" only, with a frame, for drawings at 1/4" scale or smaller (plans, building elevations, etc.)
  2. "Description" data only, without a frame, for drawings at 1/2" or larger (details).
I have created a Favorite for each of these formats. When creating a new keynote from the Keynotes palette, these favorites work great. However, if I want to apply the favorite to an already placed keynote, the specific keynote data that was referenced when the Favorite was created comes with it. This means that if at any point someone needs to change the format of their keynote, they have to not only apply the Favorite, they also have to find the correct keynote again and "Replace Label" from the keynotes palette. I attached a photo for reference, in which I applied the "Description" Favorite to the right column of keynotes (my Favorite was created from 033000.A).
@fabioferrini mentioned this, but there are no "Keynote" attributes in the element transfer settings. This means you either get all settings transferred (not only the keynote data types being referenced, but the specific keynote itself), or the label content is ignored all together. This wouldn't be a huge deal if the Favorites behaved as desired.
Dake Wells Architecture
Versions 27 or 28
2021 MacBook Pro 16", M1 Max Chip, 64gb DDR5
Browser: Google Chrome
