Keynotes Missing in AC 28 Solo
Fabucci
Keynotes not found in Document or Palettes.
Operating system used: Mac Apple Silicon Sonoma 14.6.1
cuba
Did you import your workenvironment from AC27 with all the menus?
The AC27 workenvironment in AC28 will not display keynotes...
Apple M1 Max 32 GB Ventura
AC27
The Solo Edition has never included all features of the full product, so I have to assume that this is one of those things that they've not provided to you.  But, it seems impossible to verify as there is no information on the Graphisoft web site on the solo edition of 28, and the KB article here on the community is one year old and only refers to Solo 27.   Seems you might have to contact your reseller until Graphisoft fleshes out their information here.
cuba
AC27
This is the correct answer. Thanks Cuba!!
Setup info provided by author
