.LBK DON'T OPEN
We have a 75,301 kb .lbk file showing the following message when we try to open:
Error while reading file: (name of the file) (65428: Memory full)
Why this is happened? It was working fine 5 minutes ago.
Any help?
In other .lbk files the BGAC is not working fine, it doesn't reflect the changes made in the .plp. In three different times I had to import the whole project again!!
Any clue?
Regards
I resolve what was happening with my second issue. For some misterious reason all the link files was turned into .pmk. I switch back to read as a file thru the Drawing usage.
Just wondering if you have pmk's from earlier versions of ArchiCAD in the book? I have a client with a similar problem.
Woody
s
