LEVEL MARKER CUSTOM TEXT SETTINGS
ELEVATE
I am trying to add another line of text, but cant seem to figure out how to do it. (see attached pic) I know it can be done because A Graphisoft person sent be a GIF that it can be done. I can send the gif when I can locate it
Operating system used: Windows 23H2
DMD
Try adding ... \n ... in your custom text where you want to break the text to the next line.
Barry,
Thankyou for this information.  Graphically it works using the "CUSTOM" setting, but I cant seem to get to work w/ "AUTOMATIC STORY NAMES" setting.
Can you help me get to work with "AUTOMATIC STORY NAMES" setting?
(SEE ATTACHED SNAPSHOT)
Also, the left side aligns nice, but the right side has some alignment issues. Is there a way to get the right side to have right or left justification?
Thanks again, I have been trying to get this figured out all year and you got me so close to getting this to look the way we want.  Much appreciated.
DMD
I don't have that object, but it looks as though it is automatic text or custom text.
It seems you can't have automatic text with custom text as well.
You can however alter the storey names in storey settings and you can use the ... \n ... trick there as well.
It also seems the left text is left justified and the right text is right justified and you have no settings to control that either.
Setup info provided by author
