ā2015-05-25
07:22 PM
ā2023-05-22
11:57 PM
Gordana Radonic
ā2015-05-25 07:39 PM
Kent wrote:
1. Using the Data Mapping in the "IFC Scheme Setup", the door's dimension is mapped to the IFC data.
IFC data Mapping
2. Label the Door with displaying the door's dimension as the "Additional Tags"
3. However, the door's dimension unit in the label is meter. Any help for change the unit to be mm? (Refer to the Fig. 03.)
ā2015-05-25 09:57 PM
ā2015-05-26 06:26 PM
Marcus_Scott wrote:It works! Thank you a lot!
To change the units from Metres to Millimeters for IFC fields, navigate to the Options Menu>Project Preferences>Calculation Units & Rules. A dialogue box will appear, simply set the Length Unit to Millimeter!
ā2015-05-27 01:52 PM
ā2015-05-27 06:13 PM
laszlonagy wrote:Both the WO & AC are using the IFC Scheme Setup, the rule in the dialog is shown in the attached figure.
How is the "AC" line of the Label in your image generated?
Is it generated similarly, using IFC Scheme Setup? If you, can you show the Rule in the Dialog that generates it?
ā2015-05-27 06:52 PM
ā2015-05-28 07:25 PM
ā2015-05-28 07:37 PM
