2025-12-14 02:47 PM - edited 2025-12-14 02:48 PM
A free label is connected to an element, for example, using Ctrl+Click element.
How can I disconnect a label from an element and use it as a free (unconnected) label?
Usually, when I clone a label (Move+Ctrl), the new label is also connected to the element. Sometimes this works, but sometimes it doesn't.
Therefore, I usually copy and paste to get a clone of the label, but it's no longer connected to the element.
Is there a faster way to disconnect a label from an element (without copying and pasting)?
Solved! Go to Solution.
2025-12-14 02:51 PM
You can try and convert to independent label:
2025-12-14 02:51 PM
2025-12-14 04:09 PM
Ooooo! Thank you so much!
I hadn't noticed this menu option before (Convert to Independent Label)
