gaba
Label – Quick Connect/Disconnect ?
A free label is connected to an element, for example, using Ctrl+Click element.
How can I disconnect a label from an element and use it as a free (unconnected) label?
Usually, when I clone a label (Move+Ctrl), the new label is also connected to the element. Sometimes this works, but sometimes it doesn't.
Therefore, I usually copy and paste to get a clone of the label, but it's no longer connected to the element.
Is there a faster way to disconnect a label from an element (without copying and pasting)?
"When you seek knowledge, you will eventually find it. Then you will become its source - until such time as you must seek it again."
AC 7 - 29, Twinmotion | Windows 10 Pro for Workstations
Dell 7740 Xeon | 128GB | Quadro RTX 5000 16GB + LG 2560x1080
1 Solution
CosminF
You can try and convert to independent label:
https://support.graphisoft.com/hc/en-us/articles/34548177413009-Why-do-my-labels-disappear-when-I-de...
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
2 Replies 2
CosminF
gaba
Ooooo! Thank you so much!
I hadn't noticed this menu option before (Convert to Independent Label)
